Old 10-16-2011, 01:53 PM   #3
J Tinsby
J Tinsby's Avatar
If that's the case
Originally Posted by nprboxster View Post
havent tried AM but FM is spotty. its a pioneer 7300bt
Then I would try and get the installer to try another Pioneer of the same model and see if it's any better. If it's the same then that radio is a dog or the antenna is at fault OR both 'could' be bad. If FM is bad, AM will be almost non existent, the FM freqs are much higher and require a shorter antenna to receive them.
If the installer doesn't want to play ball and satisfy you, hopefully you paid with a credit card, you can dispute the charge and get your money back.
Hopefully the installer is reputable and interested in repeat business and what you tell your buddies and tries everything to satisfy you.
Best of luck with it sounds like you have a lot of things to do with that car so far!
J T
ARRL DXCC Honor Roll | WAS | Royal Omani Radio Award | WAC
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
