Thread: Sticky Clutch
Old 10-11-2011, 12:42 PM   #1
Blackops357
Similar symptoms when starting vehicle, the clutch had to travel a little further than normal for two weeks to start then it happened! When starting as usual during the depress on the clutch I felt a pop or give way and the clutch was suck all the way down to the floor. In neutral I was able to pull it up with my foot and shift normally however cautious not to go down too far or it would get stuck again. I drove it to the shop and it was diagnosed with two leaks one in the Clutch Master Cylinder and the other in the Master Slave Cylinder. I will have both replaced at @ $900.00. I will pick up this Friday 10/15/2011.
Blackops357 is offline   Reply With Quote
