Old 10-05-2011, 05:22 AM   #1
stateofidleness
ouch.. good to know. I'll definitely mark it! I'm assuming you did this without a lift? the only part that has kept me from doing this so far is the "lowering the engine" requirement. maybe i'm scarred from the 914
I'm thinking i should be ok if I have the rear on ramps. I can then use my only floor jack for the engine part. where did you end up buying your mount from?
stateofidleness is offline   Reply With Quote
