Old 09-21-2011, 12:14 PM   #2
keithl
Originally Posted by peterbrown77
You mentioned the 19mm bolt at the center of the boomerang - can you get at it?
If so, you should be able to pop off the clamshell links. The links that drive the top are bolted to the boomerang-shaped lever, but the ones on that back that drive the clamshell are ball sockets. If you can pop those off, you can open the clamshell.
I can see it, don't know if I can get any kind of leverage to open it. It looks like it has locktite on too. Thanks.
keithl is offline   Reply With Quote
