You mentioned the 19mm bolt at the center of the boomerang - can you get at it?
If so, you should be able to pop off the clamshell links. The links that drive the top are bolted to the boomerang-shaped lever, but the ones on that back that drive the clamshell are ball sockets. If you can pop those off, you can open the clamshell.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
