Old 09-21-2011, 09:07 AM   #4
keithl
Originally Posted by dghii
Remove each cable from the motor and use a drill to slowly rotate the cable and see if each transmission will turn. If the transmissions will not turn, you may have to pop off the clips.
What year is your car?
1999. I can't get to the motor can I, the clamshell won't open? Do I have to remove
both clips that are visible on that side?
keithl is offline   Reply With Quote
