Thread: Spoiler Hack?
Old 09-13-2011, 01:43 PM   #4
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by BrokenLinkage
On many of the roads I travel, the spoiler doesn't lift until above the posted speed limit, but then doesn't retract until well below same. So if am having a bit of fun, but then slow to the speed limit, every cop I pass will see the billboard on the back of my car advertising my recent gas-wasting behavior, at least until I slow even further to retract it, something I cannot even safely monitor from the driver's seat. So I'd be interested in this hack, too, if it exists, but perhaps to raise the limits to something more meaningful aerodynamically.
If you hit the rocker switch on your fuse panel as soon as you start the car, the spoiler will stay up regardless of your speed until the car is turned off. It will stay raised, even when parked, until you start the car again and hit speeds that will cause it to function normally in the way Pedro described above. I'd say just make a habit of hitting the switch when you hop in, and it'll always be raised.
-O/D
IMSR + RMS
Robbins glass window top
