Thread: Coolant Leak
Old 08-26-2011, 07:32 AM   #16
Bobiam
Bobiam's Avatar
These cars are famous for damaging the front radiators when hitting the nose on driveways or when pulling into parking spots had putting the nose on the curb. Common failure points are where the mount that hold the radiators in the bodywork protrude from the radiator itself. And even if the unit is only slightly cracked now, it is going to get worse; and no, it cannot be repaired with expoxy from the outside.
100% correct. You need a radiator. Been there..done that.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
