Rockchalk,
Are you planning on not using the car at all during the Winter? If so then I would follow Charlie's suggestions. I would roll the car a few feet if possible every 2-3 weeks to avoid flat spotting. Since the Winters are so dry I wouldn't worry about the car getting moldy. Just keep the windows cracked a bit. Do not start the car unless you plan on driving it long enough to get the engine and all the systems completely warm and run through. Just starting your car and letting it sit in the garage is not good. I would also give all the rubber seals (trunks, doors, tires etc.) a very good dressing and would repeat it again during the Winter.
I don't Winter our car. I try to drive it a couple of times a month as long as the roads are dry and for at least 25 miles.
-Rey
