Ok, time for a bit of an update.
Haven't done any 02 bank swapping, but did use the code reader again to reset the light and see if it comes back. This time I'm reading 8 codes, some being repeats from before, but here they are:
P1117 Oxygen Sensor Heating 1 After Catalytic Converter - Below Lower Limit
P1121 Oxygen Sensor Heating 2 After Catalytic Converter - Below Lower Limit
P1124 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
P0140 Oxygen Sensor After Catalytic Converter (cylinders 1 - 3) - Interruption of Signal
P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1-3)
P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4-6) - Rich Threshold
P1411 Secondary Air Injection System - Signal Implausible (Cylinders 4-6)
P0160 Oxygen Sensor After Catalytic Converter (Cylinders 4-6) - Interruption of Signal
-O/D
IMSR + RMS
Robbins glass window top
