Thread: manual top
Old 08-18-2011, 04:19 AM   #11
schoir
Originally Posted by Canyon Racer
I converted my '02 top to manual operation after one of the cables broke. I disconnected the front bars that connect the canvas top to the transmissions. I replaced the cables and synchronized the transmissions. I now use the button to raise the clamshell then manually raise or lower the top and use the button to lower the clamshell. Just have to lower clamshell before latching the top or the switch doesn't work. I wouldn't change back now that I've lived with it. It's as fast or faster than fully motorized and provides better access to the engine hatch. Before I used the transmission for the clamshell I used a bungee cord but I was less than happy with the need to get out to operate the top. I can put the top up or down while belted in the drivers seat.
Jerry
Jerry:
Excellent workaround and you definitely have the best of both worlds. Once you made the decision that the OEM system was not worth fixing as it was delivered, that sounds to me like the way to go.
There is a hack that will let you operate the clamshell's "hydraulic" pushrods via the transmissions' V-levers, but it involves wiring into the electric motor and bypassing the double relay, IIRC.
Maybe going one step further, if you install an OEM '03 or '04 top and frame assembly as a unit, would yield the most reliable and least expensive to maintain mod, while still being able to remain seated while operating the top (i.e. "NO CHOP" !
Regards, Maurice.
Last edited by schoir; 08-18-2011 at 04:20 AM. Reason: remove duplicate salutation
schoir is offline   Reply With Quote
