Old 08-17-2011, 08:54 AM   #2
Burg Boxster
Are you sure...
more importantly, are you sure the bolt is gone? Usually what happens is the shield corrodes (due to the different metals - alum & steel) and the ensuing hole causes it to fall from the bolt. If such the case w/ yours as it has for so many others, just pick up some fender washers to put on the bolt and reattached heat shield.
