Old 08-17-2011, 08:54 AM   #13
jhandy
DRE,
I just ordered and installed the depo lights as well. The outside LEDs are the rear fog lights, and just the drivers side works anyway.
So what I did was to plug the outside LEDs into the rear light blub spot, NOT the Brake light spot, but the spot that lights up as part of the rear night lights. The problem is that the wire is too short. So to avoid cutting the wire, I cut the plastic to allow the wire to pull over to the spot.
Now I have night LEDs and LED brake lights.
bulb turn and reverse lights. and bulb drivers fog light.
2002 S
jhandy is offline   Reply With Quote
