Thread: Fresh Air Valve
Old 08-15-2011, 11:29 AM   #1
insite
they should merge behind the climatronic unit in the dash. remove the climatronic. it should have four connectors. the red wire on the beige connector feeds +5V to the mixing flaps, the footwell defrost valve, and the outside air valve.
what is the issue & what are you trying to do? what are you calling the 'reed switch'?
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
