Old 09-06-2005, 06:46 AM   #3
frankkerfoot
Whistling outside mirror(s)
At least on my 2006 Boxster S the whistling is not coming from the seam shown on the picture (i.e. the seam toward the car from the two webs which support the mirror). I temporarily put a piece of masking tape over that seam and the whistle was unchanged. I then tried tape over the seams around the bottom of the mirror pod itself, and that eliminated the whistle. Based on this I took off the tape, and rubbed some clear RTV sealant into the crack all around the bottom of the mirror (in my case only the right mirror sings- I'm not sure why). I then wiped all of the excess RTV off the surface, so it remained only within the crack. The fix is essentially invisible, but the whistle is gone.
Frank
frankkerfoot is offline   Reply With Quote
