Thread: Pay it forward
Old 08-03-2011, 10:16 AM   #17
yellowboxster01
Originally Posted by smshirk
Does this integrate? I bought a Dice but it just uses the aux jack and plugs into the headset jack on iphone. To say the the sound sux is an understatement. There is a constant hum, plus it doesn't charge. I was told you couldn't get one to integrate with a CDR 220
This cable plugs into the back of the stereo on an otherwise unused set of pins. Then you have to ground it out. I will admit I got some hum, like an interference type noise. I changed the location of the ground wire to a spot close to the passenger door away from other electronics. It reduced the hum significantly but, there was still a faint noise when no music was being played. I also “insulated” the wire harness for minimal interference.
The plug end that plugs to the ipod is the same as the charger/docking hookup.
For the price it cost compared to other cables and ipod accessories, I got my moneys worth while I had that horrible deck. I upgraded last year to the MVH8200BT Pioneer deck and it’s like night and day.
yellowboxster01 is offline   Reply With Quote
