Old 09-03-2005, 06:45 PM   #15
deliriousga
deliriousga's Avatar
In your picture, you can't see #10. See the fat one that takes up two slots? Those are #14 & 15. The one to the right of the fat one is #16. The #10 slot is directly above the #16 slot.
Click here for a drawing of the relay boxes http://www.theschillings.com/boxrelay.htm
The box you're concerned with is on the lefthand side of the page. Like xclusivecar said, always disconnect the battery or you can cost yourself some big bucks. Swap the relays and put a new fuse with the correct amperage rating in, then reconnect the battery and see what happens.
1966 Wife White/Brown Top
