Old 07-31-2011, 10:40 PM   #2
Steve Tinker
Steve Tinker's Avatar
This really sounds like air in the cooling system, but the 996 expansion bottle is different to the Boxster one, and I'm not sure if there is a bleed valve you can leave open for a couple of heat cycles to rid the system of air like you can on the Boxster.
Have a look at Rennlist.com (under 996 Forum) and use the search function - it may help with diagnosing the problem....
As a matter of interest, did your friend split the radiators (coolant and A/C) on both sides when he removed the bumper and removed the rubbish - mine looked reasonably clean untill I split the rads, then a load of leaves, grass, cig butts etc fell out and even more when I hosed out between the rad fins.
2001 MV Agusta F4.
