Old 07-22-2011, 04:51 AM   #9
jhandy
does it get louder if you turn left or right?
get to about 50, put in the clutch, and coast, turn the wheel if the front bearings are really bad, it will make the grinding noise louder when you put pressure on the bearing. IE: more noise when turning left=right bearing out.
2002 S
jhandy is offline   Reply With Quote
