Old 07-19-2011, 06:20 AM   #1
pompous
It does have a transmission computer (TCM). The reason I don't think that is the problem is because it shifts through all the gears just fine when I put it into "manual" or "tip" mode. So, that would suggest (to me) that the computer is working to change the gears and I'm back to I guess not having enough pressure inside the tranny to shift into that 5th gear (which requires the most pressure & hence that one failing). Again, these are all guesses from me, as I really know little about transmissions.
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
