Old 07-16-2011, 06:05 AM   #1
fedekz986
Be sure to keep your water drains clear ... or else
So I disconnected my battery last night to do some work, and reconnected it this morning before leaving for work. I opened the door and the window didn't move at all, which I found strange. So I went to start it - nothing. I thought hmm maybe I blew a fuse ... nope. I rechecked the battery cables to make sure they were making a good connection, everything was fine. So I just decided to disconnect and reconnect again .. well I went to disconnect the positive cable, and pull it away, and it just fell apart.
Then I remembered the small pond I had brewing in that space before I cleared the drain of the crap that was blocking it - I imagine that didn't do any good for the positive battery cable...
So make sure your drain is clear, or else you will be calling in sick like me
fedekz986 is offline   Reply With Quote
