Old 07-15-2011, 08:08 PM   #1
Paul
Porsche "Purist"
Paul's Avatar
Remove the access panels that cover the adjustment bolts and install the top on the car and if possible close all 3 latches. ID which way each side needs to go, then release the 2 red handles in the rear of the roof. Make small adjustments to each side then latch the rear handles. Repeat until happy.
Or if you have someone to help you, loosen the adjustment screws and install the top with all latches latched. Have some hold both sides where you want the top to be and tighten the adjustment screws.
1987 924S. 2002 996TT. PST-2
