Old 07-13-2011, 06:05 PM   #2
WhipE350
Autobahn Glanz
WhipE350's Avatar
Textar will work great, they too are made by TMD. Go to AdvanceAutoParts, get a can or a bunch of those little packets of brake grease and lay it on good, it should stop the squealing.
You know what I did with mine, took the original dampers, peeled them off the old brakes then used this red (can't remember the name, I can get it for you) brake grease in a bottle I got from AdvanceAutoParts as a stick-um to hold the dampers to the new pads. I then greased the dampers where they touch the caliper pistons real good...never a squeal again. The red grease really isn't a grease and it doesn't work to stop squeaks if used as normal pad grease. I complained to them and told them the stuff sucked and how could they sell it as there best stuff...it is more like a red silicone...thus it worked great as a glue for the dampers. I know all kind of weird but it worked out great in the end (brakes really work great).
