Old 07-13-2011, 03:03 PM   #3
ppbon
ppbon's Avatar
Originally Posted by dja1980
Do most go with OEM pads, or are Textar, Akebono, Mintex, etc… that I’ve seen mentioned a better option?
Do the rotors typically need to be replaced (65,000 miles)? Mine are cross-drilled… is resurfacing an option?
What all needs to be purchased to do this job correctly… pads, rotors, pad sensors, retainer kits, brake cleaner, anti-squeal glue, brake grease?
I was going to order from Suncoast, but obviously not if I buy outside of OEM. Where is the best place to order from?
OEM pads are generally Textar, Mintex, Brembo or Pagid
The rotors need to be replaced when the outer lip is 1 mm or more (that means 2 mm of wear or more)
They should not be resurfaced because they will lose more cooling mass.
If your brake light is off right now you most likely will be able to reuse the sensors.
All you need are the pads and or rotors.
Everything else can be reused.
As stated on other posts, you have a high performance car. Buy high performance brake parts for it. OEM are the best all around.
Check these DIY instructions:
http://www.pedrosgarage.com/Site_3/Replace_Brake_Pads_%26_Rotors.html
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
