Old 07-13-2011, 12:00 PM   #4
blue2000s
Porscheectomy
The reason they are telling you this is twofold:
1. The main mode of failure of a water pump is bearing wear out. Cheaper bearings=more likely failure.
2. When the bearing does fail and the impeller blades contect the engine housing, on a plastic pump, only the pump is damaged. Metal blades will damage the actual engine block. $$$
