Old 08-31-2005, 07:00 AM   #1
RandallNeighbour
You're the man, John! I must say I truly admire your willingness to learn and fix your Porsches yourself. Here's some info on the bit you couldn't investigate concerning the 3rd light being loose (it was my very first repair on my box):
Joji, what year is your Boxster? I replaced the center lamp housing on my 1997 shortly after I bought it because a few of the tiny lamps lit up intermitently. The problem was remedied most easily by replacing it.
While swapping the old for the new, I learned that it is held in place with rubber nuts, so it feels loose even when you have new ones. But, with the top up or down, the clamshell covers it and it doesn't go anywhere.
What I am not certain of is if this kind of rubber nut attachment system is the same on your model year. My original ones were falling apart making it far more loose than normal, so I replaced those while I the lamp assembly was removed.
To make my third light installation work, I had to screw the rubber nuts into the bottom of the lamp assembly and then seat the whole thing into the holes in which the nuts reside. I could not find an easy way to install the nuts from the bottom of the metal. (If I installed mine wrong, someone please correct me and tell me how to get it right!)
