Old 07-06-2011, 11:44 AM   #14
Mao_Junior
Originally Posted by ekam
You shouldn't need to muscle shifting gears whether you're upshifting or downshifting. 1st to 2nd gear shift is a bit more tough in middle of winter but that's about it. I have the 9x7 shifter assembly on mine which shortens the shift a bit but still makes it a fairly comfortable experience.
It's smooth like a bolt gun.
thanks guys!
Ekam, so if the problem for me isn't technique than I should look towards something mechanical? I've read of others changing mounts and fluids. I'm going to continue babying it until my friend has a look, then I will have mechanic do a thorough look during pending oil change.
Mao_Junior is offline   Reply With Quote
