Old 07-01-2011, 06:36 AM   #3
jhandy
The shims are stuck on with an adhesive. You should have bought new ones, but in the case you did not.....get one of your best kitchen knives. thin blade, small sharp, but long. Anyway, carefully seperate the backing from the pad trying not to bend it.
After you seperated the two, compress the pistons as usual, and apply new sealent of choice when you install the new pads.
2002 S
jhandy is offline   Reply With Quote
