Thread: 0430 Cel
Old 06-30-2011, 07:45 PM   #1
Jager
Jager's Avatar
Yes you can clean the MAF sensor, you will need a tamper resistant Torx bit (T-10) see picture below.
You can try swapping the O2 sensors but that might not tell you much, I would expect the same alarm after swapping.
Catalytic converters are very expensive and rarely are they the issue. Normally it’s a problem upstream (sensors, vacuum leaks).
Jäger
300K Mile Club
