Old 06-29-2011, 03:13 PM   #1
itsmecraig
Smile
Fantastic! I sprayed the WD40 in the rubber and the problem was rectified in seconds! (I also sprayed the door hinges a lil to make them less noisy) so strange how it initially sounds as if the creaking noise is coming from the suspension.
I also managed to stop the heat shield which was wrapped around the pipe of the exhaust from rattling on startup. happy with my Boxster again Thank you
Craig
itsmecraig is offline   Reply With Quote
