Thread: 18x10 et 65
Old 06-27-2011, 04:44 PM   #16
Cloudsurfer
Originally Posted by insite
i disagree. with only 17-18mm, certain tires will rub on the strut & ALL tires will rub excessively on the e-brake cables. you want 21-23mm spacers. this will allow you to run any tire from P265 to P285; you will still want to wire the e-brake cables out of the way a bit though.....
+1 this is absolutely correct.
Boxster S
