Thread: 18x10 et 65
Old 06-27-2011, 10:21 AM   #15
insite
Originally Posted by smshirk
you'll need 17 or 18mm spacers for the rear to put them where they need to be
i disagree. with only 17-18mm, certain tires will rub on the strut & ALL tires will rub excessively on the e-brake cables. you want 21-23mm spacers. this will allow you to run any tire from P265 to P285; you will still want to wire the e-brake cables out of the way a bit though.....
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
