Old 08-29-2005, 01:57 PM   #4
donv
donv's Avatar
Hi Randall, I presume this is the same Honda that was destined for PC guinea pig duty? Did that happen already? If so, the new slick surface may make the whole thing a lot easier...
I'd start with the mildest thing possible and work up from there. For instance, start with P21S Total Auto Wash spray, applied to a small/less conspicuous area like Brucelee says. If that doesn't work then start climbing up the chemical strength ladder, but slowly. If at all possible I'd try to stay away from anything involving scrub pads unless you're sure they won't scratch. A good microfiber may be a great help?
BTW, if the stuff is drywall mud then it will: a) fall apart with water b) be abrasive as hell to the paint if rubbed. If you could hose off most of it first... worth a try?
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
