I have a similar situation - I'd posted a thread on this too and to be safe, I'm going to replace the driver side (passenger side for me as RHD - but same side as yours) series resistor. There was some debate on whether both fans were supposed to run at low speed when the a/c is off, but no definitive answer.
I've also asked a couple of independent mechanics and they weren't sure if it's normal or not.
When only one fan is on (a/c off or a/c on but compressor off ??), the temp can go up to 92-95 degree C (probably closer to the end of 0 on you 180 mark), technically not overheating yet, when both on, the temp is only about 82-85 C).
Is your temp similar ?
Please let me if you do get both your fans to come on at low speed with a/c off. My series resistor should be arriving sometime next month, so will only be installing it then. Will let u know if that changes things.
