Old 06-20-2011, 07:59 PM   #14
jhandy
Before you run out and spend a lot of money...
the shaking.... left to right, does the speed of the shake increase with speed of the car?
If it does, it is not the bushings. It is something that is spinning.
On top of that. you can replace just the bushings if you want. You should replace the bushings on a 12 year old car anyway, but that is another topic for discussion.
you can buy them here:
store.powerflexusa.com/porsche-boxster-1997---2004-urethane-bushings-p80.aspx
If a mechanic can push or pull the bushings and it wobbles, then they are badly screwed up and would be knocking and shuddering all over the road.
You can not tell by this method. The tolerances are just too small.
2002 S
jhandy is offline   Reply With Quote
