Thread: 99 Fuel Problem
Old 06-17-2011, 06:18 PM   #1
jhandy
the fuel pump in the tank its self. Take off the union nut, pull off the sending unit. Careful not to damage the sealing ring. or worse - drop it in the tank.
Its the big round thing with an impeller attached to sending unit.
about 330$ for part.
After it is dry of fuel. hook it up to a 12 volt supply and see if it runs, if so then it is the relay.
2002 S
jhandy is offline   Reply With Quote
