Good suggestions!
But fix this ASAP or you may end up bending or twisting the clamshell which is made of aluminum and not very robust. It is pretty expensive to replace.
My guess is that the transmission cables are the issue. These have a plastic outer sheath which shrinks with time causing the cable ends to pull out of the top transmission. If one side begins to disengage or detaches, while the other stays engaged, your clamshell is gonna bend like a pretzel.
The fix is replacement. As mentioned a detailed, but not too difficult DIY.
Cheers!
