Thread: Help: DME ??
Old 06-14-2011, 01:47 PM   #5
mikefocke
DME code
P0107 Short circuit to ground – DME control module
But the theory I'd go on is you were mucking round in the engine compartment changing the AOS and you bumped some wire. I'd start by snugging up everything you could find. Then clear codes and see. ECUs are expensive...snugging up only if the object isn't your wife.
