Old 06-13-2011, 06:26 PM   #1
jhandy
unplug your battery and let it sit, then re attach the battery. The goal is to reset your computer so that it can relearn.
You will know when it is learning, when you first start it, at idle it will RPM hunt a little. Drive it hard for a little. See if that helps.
2002 S
jhandy is offline   Reply With Quote
