Old 06-13-2011, 07:32 AM   #25
insite
the only bolts you should consider replacing are for the brake calipers. the ends of the top caliper bolts are actually open to a pocket in the wheel carrier. water pools in the pocket and corrodes the bolt. when you unscrew it later, it will pull the corrosion through the aluminum & gall it. eventually, it will seize in the hole.
as for loctite? don't use it anywhere except the axle nut. i personally use red here, but if you hit the correct torque spec, it's technically unnecessary. i use loctite red on any rotating parts where the rotation moment can cause the fastener to back off. this would be the right side axle nuts & right side CV bolts.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
