Old 06-10-2011, 05:52 AM   #1
jmatta
I've always been a 911 guy and the eighties Carreras are great cars. A properly adjusted 915 trans will shift smoothly, but not like the cable shifter; there's also the classic air cooled sound. Like others have mentioned, this is not a modern car, but will hold it's value far greater than a Boxster. Only you can drive each and weigh their merits against what you are looking for. I enjoy each for what they are; truly apples to oranges.
Have a PPI done on the 911, as many replacement parts can be quite expensive; also check for worn valve guides. Good news is the 3.2 engines are pretty bullet proof and don't have issues like leaking RMS and an IMS bearing. Also check to see if the tail is factory, as I can see the front spoiler is missing and should always be there as a pair.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
