Old 06-08-2011, 04:06 PM   #1
Peter Reed
I bought the Gentex K21 Auto-Dimming reaar veiw mirror with compass and temp and the mirror wire cover from Autoanything.com for $210.
This is a great mirror with the Boxster and the outside temp and compass are a big help.
Only issue is finding a path to run the temperature probe up to the lower grills on the bumper. Had to remove the headlights, front trunk liner, etc to find a path for the cable. Had to feed it through a few rubber grommets in the firewall. It can be done!!!
Also, had to use a conventional mirror mount - just mounted it to the right of the Porsche puck. Top of the puck mount should be at least 2" below the plastic headliner.
Peter Reed is offline   Reply With Quote
