Old 06-08-2011, 07:56 AM   #1
madmods
Few things you need to double-check when enabling the alarm - see attached Alarm Guidance.
If this persist, disconnect the battery for a few minutes, reconnect, recalibrate the throttle position as per docs, set power windows limit as per docs, go for a long ride for the adaptation process, and try that alarm once again before putting everything in the bin!
Hope this helps a bit mate - fingers crossed.
madmods is offline   Reply With Quote
