Old 06-06-2011, 03:45 PM   #1
Frodo
Well, yeah, I did run into that issue, unfortunately. The way it is now, there's no way to get the wheel spindle/ABS (#5 on your pic) piece out. (Things may have changed between '99 and '01?)
Okay, Insite, onto what you were recommending. I loosened the top end-link bolt at the top of the wheel bearing carrier:
Doesn't that also help hold the wheel bearing carrier to the strut? I should push that bolt all the way through and out (ie, to the left in my pic)?
Keeping in mind that I'm an admitted noob, here's where I also start to run into terminology problems. You say to loosen the lower control arm bolt. Now 101 Projects refers to the components of the suspension as the 'wishbone' and 'control arm'. Bentley calls the same pieces the 'transverse control arm' and the 'diagonal control arm.' They're all the same thing, right? So when you talk about loosening the lower control arm bolt, are you talking about the bolt by the nickle (next to the ball joint)? If so, again: do I take it all the way out or just loosen it?
I know these are idiotic questions, I just want to do this right the first time...
