Old 05-24-2011, 05:07 PM   #1
jaykay
jaykay's Avatar
Would there be an alternate method of flushing the coolant system...perhaps a pressure bleed system that would avoid you having to do this?
Make sure the car is really on those stands before starting...vibrations can make things shift over time. Are you having it sit on rubber or? You might want to weld on some jack stand pads with locking pins for the jacking points.
986 00S
