Old 05-18-2011, 05:23 PM   #3
timurbin
Thanks for the listing! I looked at the left control arm tonight (since that side is disassembled!) and sure enough- you can see the grease from the ball joint at the front end of the arm leaked all over the arm and the socket is torn. The listing you gave actually proves to be better deal than any place else I have found for oem parts.
Any reason why the seller says professional installation is required? Anything special about them that you found when installing yours? I need an alignment anyway along with new tires so... but any tips appreciated!
In any case, I owe you one theitalianflip!
Tim
timurbin is offline   Reply With Quote
