Thread: Hot issue
Old 05-07-2011, 11:44 AM   #3
BYprodriver
BYprodriver's Avatar
Originally Posted by Hooker012
I have a 99 boxster. Ok i will try to explain this to the best of my ability. When I drive the car and let it get to operating temperature. I turn it off and come back a little later it has the hardest time starting back up. If it sits for a few hours it will start up just fine. Even if I havent driven the car and its hot ouside like in the 90s it does the same thing. It does not throw me any codes or anything. I only run premium fuel in it and all that good stuff. Any good ideas would help at this time.
If your Boxster is cranking slowly when it's hot most likely you have a loose/dirty/corroded/bad ground maybe @ starter cables or the starter is going bad. If it cranks normal speed 1st guess is fuel pump. Fuel pump is cooled by the fuel so if you run low fuel level that worsens the problem.
