Old 05-05-2011, 09:23 AM   #2
rdougan
Originally Posted by manolo
A cheap fix that may help some of your electrical problems is a new ignition switch. I had similar electrical gremlins that turned out to be the switch. When it goes, it causes all types of weird things in the electrical system (my low beams didnt work but highs did, windows didnt work, locks, top etc.) I bought an $11 switch and it fixed it all. Another telltale sign is that the key becomes difficult to go in/out of the ignition switch.
I'm in the East Bay and might be able to help you with the switch or loan you the tool I made, depending on my work load.
Cool, thanks.
Does it *need* to be difficult to insert and remove the key for this to cause a problem?
rdougan is offline   Reply With Quote
