Old 04-30-2011, 05:17 AM   #1
tonycarreon
tonycarreon's Avatar
Originally Posted by Tobz
Thats doesnt make any sense.
that's because it's spam.
just a quick note, if i am remembering correctly...
to remove, you turn the wrench forward, towards the front of the car. the suggestion is to leave it in place and let it "fall" back down. however, i never do. when i insert the headlamp assembly, the groove that catches the hook is not flush with the assembly holder, but slightly up (again i may be doing it wrong) and once the headlight is slid most of the way back in (90% maybe?) i put the wrench back in, push the headlight and can see the wrench start to turn, then turn the wrench in the opposite direction - so that it points towards the rear of the car. there is a very loud POP and the headlight is locked in place.
