Old 04-29-2011, 08:59 AM   #1
DFW02S
DFW02S's Avatar
The distance between the mounting surface on the hub and the center of the wheel.
When you add a spacer the offset/et is reduced by the spacer size because you're moving the center of the wheel closer to the mounting surface on the hub.
I actually struggled for a bit with understanding offset. Now I has it undr control.
DFW02S is offline   Reply With Quote
